Zum Hauptinhalt wechseln
Toilet Keeps Running: How to Fix & Maintain Valve Seat
Was du brauchst
  1. Toilet Keeps Running: How to Fix & Maintain Valve Seat, Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 1, Bild 1 von 1
    • Remove the lid from the toilet tank.
  2. Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 2, Bild 1 von 1
    • Flush the toilet, and hold down the flush lever until the tank is completely empty.
  3. Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 3, Bild 1 von 1
    • Gently lift the float up, ending the flow of water. This will prevent the toilet tank from refilling.
  4. Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 4, Bild 1 von 3 Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 4, Bild 2 von 3 Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 4, Bild 3 von 3
    • Pull up the valve seat. If possible, keep it raised without releasing the float.
    • If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step.
    • Some toilets may use a float ball to control overflow.
  5. Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 5, Bild 1 von 2 Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 5, Bild 2 von 2
    • Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well.
  6. Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 6, Bild 1 von 2 Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 6, Bild 2 von 2
    • Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume.
  7. Toilet Keeps Running: How to Fix & Maintain Valve Seat: Schritt 7, Bild 1 von 1
    • Place the lid back on the tank.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Roman Snow
169 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G37, Cardinal Spring 2020 Mitglied von UW Tacoma, Team S1-G37, Cardinal Spring 2020
UWT-CARDINAL-S20S1G37
1 Mitglied
3 Kommentare
Cutting off the water supply, draining the tank and spraying the seat with vinegar or CLR does the same thing -dissolving the calcium carbonate. You can prevent calcium carbonate buildup by putting a piece of magnesium in the tank.
P Schmied - Antwort
Thanks for Step #7. Always forget that one!
Matt Heckel - Antwort
You may use a calcium remover for toilets. If you have patience and willingness, you can make a DIY toilet cleaner composed of vinegar, lemon, other acidic liquids, and baking soda. Thick calcium deposits in the toilet require muriatic acid and deep scrubbing with scour paper.
lim anna - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 62
Insgesamt: 779
