Zum Hauptinhalt wechseln
PlayStation 2 Slimline SPU-3170 Laser Replacement
Was du brauchst
  1. PlayStation 2 Slimline SPU-3170 Laser Replacement, Outer Shell: Schritt 1, Bild 1 von 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 2, Bild 1 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 2, Bild 2 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 2, Bild 3 von 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 3, Bild 1 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 3, Bild 2 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 3, Bild 3 von 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 4, Bild 1 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 4, Bild 2 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement: Schritt 4, Bild 3 von 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove screws and white tab: Schritt 5, Bild 1 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove screws and white tab: Schritt 5, Bild 2 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove screws and white tab: Schritt 5, Bild 3 von 3
    • Remove the 2 philips screws, marked in red.
    • Remove the white plastic slider holder.
    • Picture 3 shows how it should be done.
  6. PlayStation 2 Slimline SPU-3170 Laser Replacement, Remove slider: Schritt 6, Bild 1 von 1
    • Remove the slider as shown in the picture. You could do this with your fingers, otherwise take tweezers to remove it.
  7. PlayStation 2 Slimline SPU-3170 Laser Replacement, Disconnect the laser: Schritt 7, Bild 1 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement, Disconnect the laser: Schritt 7, Bild 2 von 3 PlayStation 2 Slimline SPU-3170 Laser Replacement, Disconnect the laser: Schritt 7, Bild 3 von 3
    • Do not remove the laser yet!
    • Take the laser out of the rail and rotate it.
    • Open up the connector by both sides with your fingernail or spudger. Be EXTREME carefull here, as it can break easily! (if the laser is broken, it won't matter, you can even practice on the broken laser).
    • Take the ribbon cable out, it should come out with ease.
  8. PlayStation 2 Slimline SPU-3170 Laser Replacement, Transfer slider: Schritt 8, Bild 1 von 2 PlayStation 2 Slimline SPU-3170 Laser Replacement, Transfer slider: Schritt 8, Bild 2 von 2
    • Remove the philips screw from the laser and take off the slider.
    • Transfer the slider to the new laser and screw it down.
  9. PlayStation 2 Slimline SPU-3170 Laser Replacement, Desolder anti-static security: Schritt 9, Bild 1 von 2 PlayStation 2 Slimline SPU-3170 Laser Replacement, Desolder anti-static security: Schritt 9, Bild 2 von 2
    • Most of the lasers have some solder on it for the anti-static security. You NEED to remove the solder, otherwise it won't work. Remove the solder with desolder wick.
    • You need a soldering station to DESOLDER the anti-static (if it's there), without de-soldering it, the laser could be busted!!
    • 2nd picture shows how it should be done. If you have the same result, your good to go. If you are not sure, just use your soldering iron again to remove some more (don't hold it too long on it, otherwise you could damage something).
  10. PlayStation 2 Slimline SPU-3170 Laser Replacement, Laser assembly: Schritt 10, Bild 1 von 1
    • Remove the blue sticker from the laser (if it has one). Put the laser back in and all other removed components (follow guide in reverse order). When you've put everything back, it should look like the provided picture.
Abschluss
To reassemble your device, follow these instructions in reverse order. Do not forget to transfer the slider from the old laser to the new one!
4 weitere Nutzer:innen haben diese Anleitung absolviert.
koppie007
11.764 Reputation
9 Anleitungen geschrieben
Protectors Of The Game Systems Mitglied von Protectors Of The Game Systems
Community
4 Mitglieder
24 Anleitungen geschrieben
3 Kommentare
Hi there,
Do you need to worry about the laser cd/dvd parameters when installing the new one?
Thanks
Simon
Simon Jones - Antwort
Hi Simon! No, for the PS2 slim, this is not the case. Regarding the "PS2 Phat", sometimes it is required to adjust the parameters, same for the PS1.
koppie007 -
Hi there. I need help! How can I replace the same central engine. In other models it is simple, but here it is rigidly attached to the frame. I will be grateful for your help. thank you
Alex - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 36
Letzte 30 Tage: 203
Insgesamt: 6,367
