Zum Hauptinhalt wechseln
2010-2017 Suzuki Swift Cabin Air Filter Replacement
Was du brauchst
  1. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: Schritt 1, Bild 1 von 3 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: Schritt 1, Bild 2 von 3 2010-2017 Suzuki Swift Cabin Air Filter Replacement, remove the glovebox: Schritt 1, Bild 3 von 3
    • The cabin air filter is located behind the glovebox. To access it, the glovebox needs to be removed.
    • After opening, 2 supports on the back of the glovebox prevent the glovebox from falling on the floor.
    • With your hands, push the left support to the right, making sure the rubber band doesn't catch on the frame.
    • If the left support can move freely, pull the glovebox towards you and to the left, to also free the right support.
    • Pull the glovebox towards you to pull the bottom hinges free.
  2. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, replace the filter: Schritt 2, Bild 1 von 2 2010-2017 Suzuki Swift Cabin Air Filter Replacement, replace the filter: Schritt 2, Bild 2 von 2
    • The cabin air filter can be accessed by removing the cover from the filter housing.
    • Get your fingers behind the cover latches and pull the cover toward you, removing the cover.
    • Pull the filter out, and prevent dirt from falling out.
    • Put the new filter in, and make sure to follow the design of your filter manufacturer (air is pulled in from the top).
    • Put the cover back.
  3. 2010-2017 Suzuki Swift Cabin Air Filter Replacement, put back the glovebox: Schritt 3, Bild 1 von 2 2010-2017 Suzuki Swift Cabin Air Filter Replacement, put back the glovebox: Schritt 3, Bild 2 von 2
    • Put the glovebox hinge parts back into the frame hinge parts.
    • Lift the glovebox and push equally on both sides to force the supports back behind the frame.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
knipwim
8.527 Reputation
30 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 52
Letzte 30 Tage: 228
Insgesamt: 6,788
