Einleitung
Need to know how to replace the filter for a water filtration system? I am going to show you how to do this so that you can drink clean, filtered water. There is no risk during this procedure and it is simple; no background experience is needed. This is a helpful guide to show you how to replace a used water filter.
Note: Filters need to be changed every three months, otherwise the water will be undrinkable and can pose health risks.
Was du brauchst
Press the button on the top of the filtration device to release water pressure and let excess water drain.
Put the new filter inside the filter canister, making sure it goes in properly.
Screw the filter canister back into place using the canister wrench, making sure it's tightly screwed in.
You have now successfully replaced your water filter.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
