Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-T9 AV Port Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-T9 AV Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 2, Bild 1 von 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 AV Port Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • This is the camera without the front cover.
  4. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 4, Bild 1 von 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 5, Bild 1 von 3 Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 5, Bild 2 von 3 Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 5, Bild 3 von 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 6, Bild 3 von 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the back cover.
  8. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 8, Bild 1 von 1
    • The back cover is now removed from the internal hardware.
  9. Sony Cyber-shot DSC-T9 AV Port Replacement, CCD Module: Schritt 9, Bild 1 von 1
    • This is the CCD module.
  10. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 10, Bild 1 von 1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  11. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 11, Bild 1 von 1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  12. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 12, Bild 1 von 1
    • The CCD module is now removed from the camera.
  13. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: Schritt 13, Bild 1 von 2 Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: Schritt 13, Bild 2 von 2
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  14. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 14, Bild 1 von 1
    • Remove metal screw plate.
  15. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 15, Bild 1 von 1
    • Use pry stick to pop off ribbon.
  16. Sony Cyber-shot DSC-T9 AV Port Replacement: Schritt 16, Bild 1 von 1
    • Remove AV port from camera.
Abschluss
Clemson, Team 13-1, Benson Spring 2013 Mitglied von Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 604
