Zum Hauptinhalt wechseln
Dreamer Autoshade Motor Set Screw Adjustment
Was du brauchst
  1. Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: Schritt 1, Bild 1 von 2 Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: Schritt 1, Bild 2 von 2
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
  2. Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: Schritt 2, Bild 1 von 2 Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: Schritt 2, Bild 2 von 2
    • Using a flathead screwdriver, pry the bearing cap from the tube.
  3. Dreamer Autoshade Motor Set Screw Adjustment, Tighten Motor Set Screw: Schritt 3, Bild 1 von 1
    • Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
    • The hub should fit snugly on the shaft, unable to rotate freely.
    • Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
Abschluss
David
734 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 141
