Zum Hauptinhalt wechseln
iPhone 12 Screen Refurbishment
Einführungsvideo
  1. iPhone 12 Screen Refurbishment, Cosmetic Inspection: Schritt 1, Bild 1 von 2 iPhone 12 Screen Refurbishment, Cosmetic Inspection: Schritt 1, Bild 2 von 2
    • Firstly, let's run a cosmetic inspection of the screen. We can see that the iPhone 12 has a narrower bezel than the iPhone 11 Pro, so the iPhone 12 bezel may be a little easier to disassemble.
    • In addition to that, the iPhone 12 bezel doesn’t wrap around the glass lens anymore. Therefore, the material requirements for the bezel adhesive will be relatively high to prevent the adhesive from falling off. To dig deeper, we will refurbish the iPhone 12 screen.
  2. iPhone 12 Screen Refurbishment, Screen Testing: Schritt 2, Bild 1 von 3 iPhone 12 Screen Refurbishment, Screen Testing: Schritt 2, Bild 2 von 3 iPhone 12 Screen Refurbishment, Screen Testing: Schritt 2, Bild 3 von 3
    • First of all, let’s test the screen. The display, touch, and 3D Touch all function well.
    • Place the screen upside down on the Screen Separator, set the temperature to 100 ℃, and start the suction.
  3. iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 3, Bild 1 von 2 iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 3, Bild 2 von 2
    • Remove the ear speaker flex cable first. Since the ear speaker flex cable is very easy to damage, please be noted that we need to heat the screen before removing it.
    • Besides, the iPhone 12 ear speaker sensor ring is integrated into the bezel.
  4. iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 4, Bild 1 von 3 iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 4, Bild 2 von 3 iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 4, Bild 3 von 3
    • Now, let’s remove the bezel. Dip adhesive remover on the bezel first.
    • While using the Razor Blade to separate the bezel, you need to dip some adhesive remover too.
    • Slide the Razor Blade back and forth, and pry up the bezel carefully.
  5. iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 5, Bild 1 von 3 iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 5, Bild 2 von 3 iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 5, Bild 3 von 3
    • As the ear speaker flex cable part has more adhesive, we can dip more adhesive remover to make it loose.
    • Hold the two corners of the bezel in both hands, and detach the bezel slowly with caution.
    • Our original thought was to separate the bezel in a complete manner and then reuse it. But now the bezel is broken here. So please notice that this part of the bezel is made of plastic material, which is extremely easy to break. If you want to separate the bezel completely, you need to pay extra attention.
  6. iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 6, Bild 1 von 2 iPhone 12 Screen Refurbishment, Bezel Removing: Schritt 6, Bild 2 von 2
    • In order not to induce damage, we use a thin film to remove the flex cable part.
    • Remove the bezel and it can be seen that the 3M adhesive used in the bezel flex cable part is no longer the cold adhesive. The 3M adhesive makes the bezel relatively easy to remove.
  7. iPhone 12 Screen Refurbishment, Glass Lens Separating: Schritt 7, Bild 1 von 3 iPhone 12 Screen Refurbishment, Glass Lens Separating: Schritt 7, Bild 2 von 3 iPhone 12 Screen Refurbishment, Glass Lens Separating: Schritt 7, Bild 3 von 3
    • Remove excess adhesive on the ear speaker flex cable part.
    • Start separating the OLED along the bottom layer of the glass lens with Cutting Wire.
    • Through our observation, we found that the touch panel of the iPhone 12 screen is better than that of the iPhone 11 Pro, which is not easy to damage. To put it specifically, the touch panel of the iPhone 12 is thicker and the cut lines are clearer and wider.
  8. iPhone 12 Screen Refurbishment, OCA Adhesive Removing: Schritt 8, Bild 1 von 3 iPhone 12 Screen Refurbishment, OCA Adhesive Removing: Schritt 8, Bild 2 von 3 iPhone 12 Screen Refurbishment, OCA Adhesive Removing: Schritt 8, Bild 3 von 3
    • Place the OLED on the heating platform.
    • Roll up the OCA adhesive with the Electric Adhesive Removing Tool and remove the remaining OCA adhesive with a hand.
  9. iPhone 12 Screen Refurbishment, OCA Adhesive Removing: Schritt 9, Bild 1 von 3 iPhone 12 Screen Refurbishment, OCA Adhesive Removing: Schritt 9, Bild 2 von 3 iPhone 12 Screen Refurbishment, OCA Adhesive Removing: Schritt 9, Bild 3 von 3
    • Connect the OLED and ear speaker flex cable. The display and touch function works well.
    • A point worth mentioning is that not connecting the ear speaker flex cable will lead to the absence of light-sensing. The screen will be too dark to be tested.
  10. iPhone 12 Screen Refurbishment, Laminating: Schritt 10, Bild 1 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 10, Bild 2 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 10, Bild 3 von 3
    • Attach the OCA adhesive to the glass lens.
    • Put the glass lens with OCA adhesive into the Bubble Removing Machine for 3 minutes.
    • Then put it into the UV Lamp for Curing OCA Glue for 5 seconds.
  11. iPhone 12 Screen Refurbishment, Laminating: Schritt 11, Bild 1 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 11, Bild 2 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 11, Bild 3 von 3
    • Wipe clean the OLED and use the pull tape to stick a corner of the glass lens.
    • Press the pull tape for seconds and then tear off the protective film of the OCA adhesive.
  12. iPhone 12 Screen Refurbishment, Laminating: Schritt 12, Bild 1 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 12, Bild 2 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 12, Bild 3 von 3
    • Since the iPhone 12 aligning mold has not come out yet, we use manual alignment.
    • After alignment, place the screen on the laminating sponge.
    • Please notice that two slots are cut on the sponge in order to prevent OLED damage.
  13. iPhone 12 Screen Refurbishment, Laminating: Schritt 13, Bild 1 von 2 iPhone 12 Screen Refurbishment, Laminating: Schritt 13, Bild 2 von 2
    • Put the screen into the laminating machine and press “LCD laminate start”.
    • Take out the screen and we can see there are bubbles on the screen.
  14. iPhone 12 Screen Refurbishment, Laminating: Schritt 14, Bild 1 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 14, Bild 2 von 3 iPhone 12 Screen Refurbishment, Laminating: Schritt 14, Bild 3 von 3
    • Put the screen back into the Bubble Removing Machine for 10 minutes and then put the screen into the UV Lamp for Curing OCA Glue for 180 seconds.
    • Assemble the refurbished screen on the phone and all functions work well.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
REWA
14.204 Reputation
53 Anleitungen geschrieben
3 Kommentare
This is way more complicated than it needs to be.
Crystal Haugh - Antwort
Is there anyway to do this without a bubble removal machine
Dylan - Antwort
Yes, you need to use LOCA. Check out ECDiy on YT
Bryce Shaw -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 41
Letzte 30 Tage: 173
Insgesamt: 9,831
