Zum Hauptinhalt wechseln
How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
Was du brauchst
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 1, Bild 1 von 1
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 2, Bild 1 von 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 2, Bild 2 von 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 3, Bild 1 von 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 3, Bild 2 von 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 3, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 4, Bild 1 von 2 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 4, Bild 2 von 2
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 5, Bild 1 von 1
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: Schritt 6, Bild 1 von 1
    • Insert battery back into position with the flat side facing upwards.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S1-G3, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G3, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G3
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 51
Letzte 30 Tage: 183
Insgesamt: 4,345
