Zum Hauptinhalt wechseln
Raidmax Alpha Case Graphics Card Replacement
Was du brauchst
  1. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: Schritt 1, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: Schritt 1, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: Schritt 1, Bild 3 von 3
    • Turn off the computer and the power supply to the computer.
  2. Raidmax Alpha Case Graphics Card Replacement: Schritt 2, Bild 1 von 2 Raidmax Alpha Case Graphics Card Replacement: Schritt 2, Bild 2 von 2
    • Recycle the power in the computer by pressing the power button on and off again. This removes any remaining current to the computer.
  3. Raidmax Alpha Case Graphics Card Replacement: Schritt 3, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 3, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 3, Bild 3 von 3
    • Access the glass side panel by turning the back of the case to the left when looking at it from the front.
  4. Raidmax Alpha Case Graphics Card Replacement: Schritt 4, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 4, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 4, Bild 3 von 3
    • Remove the two screws on the glass side panel. These are thumb screws so they can simply be removed by twisting them to the left.
  5. Raidmax Alpha Case Graphics Card Replacement: Schritt 5, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 5, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 5, Bild 3 von 3
    • Carefully slide the glass panel to the left and then pull it off to remove it.
  6. Raidmax Alpha Case Graphics Card Replacement: Schritt 6, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 6, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 6, Bild 3 von 3
    • Tilt the case backward and lay it on its backside. This is done so the card will not pull down when being removed.
  7. Raidmax Alpha Case Graphics Card Replacement: Schritt 7, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 7, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 7, Bild 3 von 3
    • Undo the power connection to the card. Push the clip on the connector and pull the cable up.
  8. Raidmax Alpha Case Graphics Card Replacement: Schritt 8, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 8, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 8, Bild 3 von 3
    • Remove three 6.3 mm screws to the card located on the left side of the case using a Phillips #2 screwdriver.
  9. Raidmax Alpha Case Graphics Card Replacement: Schritt 9, Bild 1 von 2 Raidmax Alpha Case Graphics Card Replacement: Schritt 9, Bild 2 von 2
    • Push down the clip to the motherboard circled in red.
  10. Raidmax Alpha Case Graphics Card Replacement: Schritt 10, Bild 1 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 10, Bild 2 von 3 Raidmax Alpha Case Graphics Card Replacement: Schritt 10, Bild 3 von 3
    • Carefully grip the old graphics card with two hands and lift it out of the case.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 51
Insgesamt: 3,156
