Zum Hauptinhalt wechseln
Nikon Coolpix S630 LCD Screen Replacement
Was du brauchst
  1. Nikon Coolpix S630 LCD Screen Replacement, Battery Compartment: Schritt 1, Bild 1 von 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 LCD Screen Replacement, Battery: Schritt 2, Bild 1 von 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 LCD Screen Replacement, Memory Card: Schritt 3, Bild 1 von 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 LCD Screen Replacement, Back Cover Removal: Schritt 4, Bild 1 von 3 Nikon Coolpix S630 LCD Screen Replacement, Back Cover Removal: Schritt 4, Bild 2 von 3 Nikon Coolpix S630 LCD Screen Replacement, Back Cover Removal: Schritt 4, Bild 3 von 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 LCD Screen Replacement, Detaching Ribbon: Schritt 6, Bild 1 von 2 Nikon Coolpix S630 LCD Screen Replacement, Detaching Ribbon: Schritt 6, Bild 2 von 2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 LCD Screen Replacement, LCD Screen Removal: Schritt 7, Bild 1 von 3 Nikon Coolpix S630 LCD Screen Replacement, LCD Screen Removal: Schritt 7, Bild 2 von 3 Nikon Coolpix S630 LCD Screen Replacement, LCD Screen Removal: Schritt 7, Bild 3 von 3
    • Lift LCD screen carefully from the metal casing
    • Be cautious when lifting screen as it is still connected to the logic board by two ribbons
    • Lift the two tabs for both ribbons with a plastic case opener like in the previous step
    • Pull out ribbons gently from the logic board with tweezers to disconnect screen
  8. Nikon Coolpix S630 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the LCD screen from the logic board!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Anna Katrina
28 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-56, Johann Spring 2013 Mitglied von Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 1,009
