Zum Hauptinhalt wechseln
iPad Air 3 Volume Button Cable Replacement
Was du brauchst
  1. iPad Air 3 Volume Button Cable Replacement, Prepare an iOpener: Schritt 1, Bild 1 von 1
    • Strong adhesive holds the screen in place. In order to separate it, you'll first need to heat and soften the adhesive using an iOpener, hair dryer, or heat gun.
    • You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
    • Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
  2. iPad Air 3 Volume Button Cable Replacement, Create an opening gap: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Clamp
    $24.95
    Kaufen
    • If your iPad's screen is badly cracked, wear skin and eye protection. Cover the screen with a smooth layer of clear packing tape to contain glass shards and help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    • Place a suction cup next to the iPad's home button and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • If you want to use the Anti-Clamp, a tool we designed to make the opening procedure easier, follow this guide.
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Don't pull too hard, or you may shatter the glass. If necessary, apply more heat to further soften the adhesive.
    • Once you've opened a sufficient gap, insert an opening pick into the gap.
  3. iPad Air 3 Volume Button Cable Replacement, Slice through the bottom adhesive: Schritt 3, Bild 1 von 2 iPad Air 3 Volume Button Cable Replacement, Slice through the bottom adhesive: Schritt 3, Bild 2 von 2
    • Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
    • Leave the pick in place temporarily to prevent the adhesive from re-sealing.
  4. iPad Air 3 Volume Button Cable Replacement, Slice through the left adhesive: Schritt 4, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement, Slice through the left adhesive: Schritt 4, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement, Slice through the left adhesive: Schritt 4, Bild 3 von 3
    • Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
    • Insert a second opening pick at the bottom left corner of the iPad.
    • Slide the second opening pick along the left side of the display to separate the adhesive underneath.
    • Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
  5. iPad Air 3 Volume Button Cable Replacement: Schritt 5, Bild 1 von 1
    • Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
  6. iPad Air 3 Volume Button Cable Replacement: Schritt 6, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 6, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 6, Bild 3 von 3
    • Insert a third opening pick at the top left corner of the iPad.
    • Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
    • The front-facing camera is located right in the center of the iPad's top edge and can be damaged if the pick is inserted too far. Only insert the tip of the opening pick when cutting near the camera.
  7. iPad Air 3 Volume Button Cable Replacement: Schritt 7, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 7, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 7, Bild 3 von 3
    • Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • Insert a fourth opening pick at the top right corner of the iPad.
    • Slide the opening pick down to the bottom right corner to cut the adhesive.
    • Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
  8. iPad Air 3 Volume Button Cable Replacement: Schritt 8, Bild 1 von 2 iPad Air 3 Volume Button Cable Replacement: Schritt 8, Bild 2 von 2
    • Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
    • Gently twist the pick to separate the display assembly from the iPad.
    • Don't try to remove the display all the way yet! It is still connected to the iPad's motherboard.
    • If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
  9. iPad Air 3 Volume Button Cable Replacement: Schritt 9, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 9, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 9, Bild 3 von 3
    • Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
    • Don't lift the display more than 70° or you may damage the attached ribbon cables.
  10. iPad Air 3 Volume Button Cable Replacement: Schritt 10, Bild 1 von 2 iPad Air 3 Volume Button Cable Replacement: Schritt 10, Bild 2 von 2
    Magnetic Project Mat
    $19.95
    Kaufen
    • Remove the 1.9 mm Phillips screw that secures the battery power connector.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  11. iPad Air 3 Volume Button Cable Replacement, Battery connector information: Schritt 11, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement, Battery connector information: Schritt 11, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement, Battery connector information: Schritt 11, Bild 3 von 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  12. iPad Air 3 Volume Button Cable Replacement, Disconnect the battery: Schritt 12, Bild 1 von 1
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • To disconnect the battery, slide one prong of a battery blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages.
    • Leave the battery blocker in place as you work.
  13. iPad Air 3 Volume Button Cable Replacement: Schritt 13, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 13, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 13, Bild 3 von 3
    • Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
    • Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
    • You may need to angle the driver slightly in order to avoid straining the ribbon cables.
    • Remove the display connector cover bracket.
  14. iPad Air 3 Volume Button Cable Replacement: Schritt 14, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 14, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 14, Bild 3 von 3
    • Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Air 3 Volume Button Cable Replacement: Schritt 15, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 15, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 15, Bild 3 von 3
    • Underneath, you'll find two additional display cable connectors.
    • Use your spudger to gently pry them up and disconnect them.
  16. iPad Air 3 Volume Button Cable Replacement: Schritt 16, Bild 1 von 1
    • Remove the display assembly.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing display, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  17. iPad Air 3 Volume Button Cable Replacement, Remove the upper component bracket screws: Schritt 17, Bild 1 von 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 2.4 mm-long screws
  18. iPad Air 3 Volume Button Cable Replacement, Free the upper component bracket: Schritt 18, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement, Free the upper component bracket: Schritt 18, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement, Free the upper component bracket: Schritt 18, Bild 3 von 3
    • Use a spudger to push the upper component bracket towards the upper edge and off of the clips located near the rear camera.
  19. iPad Air 3 Volume Button Cable Replacement, Remove the upper component bracket: Schritt 19, Bild 1 von 2 iPad Air 3 Volume Button Cable Replacement, Remove the upper component bracket: Schritt 19, Bild 2 von 2
    • Remove the upper component bracket.
    • During reassembly, make sure that the upper component bracket slides under the clips near the rear camera.
  20. iPad Air 3 Volume Button Cable Replacement, Disconnect the volume button cable: Schritt 20, Bild 1 von 2 iPad Air 3 Volume Button Cable Replacement, Disconnect the volume button cable: Schritt 20, Bild 2 von 2
    • Use the pointed end of a spudger to disconnect the volume button cable by lifting straight up on the press connector.
  21. iPad Air 3 Volume Button Cable Replacement, Remove the volume button bracket screws: Schritt 21, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 1.9 mm-long screws securing the volume button bracket to the rear case.
  22. iPad Air 3 Volume Button Cable Replacement, Remove the volume button bracket: Schritt 22, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement, Remove the volume button bracket: Schritt 22, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement, Remove the volume button bracket: Schritt 22, Bild 3 von 3
    • Insert an opening pick between the volume button cable and the rear case.
    • Slide it towards the rear camera to cut the adhesive securing the volume cable to the rear case.
  23. iPad Air 3 Volume Button Cable Replacement: Schritt 23, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 23, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 23, Bild 3 von 3
    • The upper and lower volume button covers may fall out while you're removing the volume button bracket. Be sure not to lose them.
    • Use the flat end of a spudger to push the upper volume button back into the rear case.
    • Repeat for the lower volume button.
  24. iPad Air 3 Volume Button Cable Replacement: Schritt 24, Bild 1 von 1
    • Remove the volume button bracket from the rear case.
  25. iPad Air 3 Volume Button Cable Replacement, Loosen the adhesive: Schritt 25, Bild 1 von 2 iPad Air 3 Volume Button Cable Replacement, Loosen the adhesive: Schritt 25, Bild 2 von 2
    • Apply a heated iOpener to the volume button assembly for thirty seconds.
  26. iPad Air 3 Volume Button Cable Replacement, Peel off the volume button cable: Schritt 26, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement, Peel off the volume button cable: Schritt 26, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement, Peel off the volume button cable: Schritt 26, Bild 3 von 3
    • The next four steps show how to separate the volume button cable from the button bracket.
    • Use an opening pick or a halberd spudger to peel the volume button cable away from the bracket.
  27. iPad Air 3 Volume Button Cable Replacement: Schritt 27, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 27, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 27, Bild 3 von 3
    • Insert an opening pick or a halberd spudger underneath the lower volume button to peel it away from the bracket.
  28. iPad Air 3 Volume Button Cable Replacement: Schritt 28, Bild 1 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 28, Bild 2 von 3 iPad Air 3 Volume Button Cable Replacement: Schritt 28, Bild 3 von 3
    • Insert an opening pick or a halberd spudger underneath the upper volume button to peel it away from the bracket.
  29. iPad Air 3 Volume Button Cable Replacement: Schritt 29, Bild 1 von 1
    • Remove the volume button cable from the bracket.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to attach the new cable to the volume button bracket.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 3 Answers community for help.
Robert Boyd
26.479 Reputation
94 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 461
