Zum Hauptinhalt wechseln
Toshiba Portege M300 Keyboard Replacement
Was du brauchst
  1. Toshiba Portege M300 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the rest of the cover by sliding it to the right and lifting the edge.
  6. Toshiba Portege M300 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard.
    • Two 4.0 mm coarse thread screws.
  7. Toshiba Portege M300 Keyboard Replacement: Schritt 7, Bild 1 von 3 Toshiba Portege M300 Keyboard Replacement: Schritt 7, Bild 2 von 3 Toshiba Portege M300 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the Torx screw holding the left keyboard tab in place, and lift it to release.
    • One Torx T6 fine thread screw.
  8. Toshiba Portege M300 Keyboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Turn the computer over on to the back.
    • Remove the middle screw with a Phillips head #000 screwdriver.
    • One 7.5 mm fine thread screw.
  9. Toshiba Portege M300 Keyboard Replacement: Schritt 9, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Turn the computer over to the front.
    • Gently pull at the top and bottom to remove the keyboard.
    • Peel off the black tape that holds the connection wire.
  10. Toshiba Portege M300 Keyboard Replacement: Schritt 10, Bild 1 von 2 Toshiba Portege M300 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Flip the keyboard over and carefully unplug the connection wire.
    • Reverse the steps for proper instillation of the new keyboard.
Abschluss
Alison Wendt
135 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-51, Johann Spring 2013 Mitglied von Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,241
