Einleitung
This guide goes through the steps needed to install a new keyboard. Attention to detail is required in order to reverse the steps for instillation of a new keyboard, returning each screw to the correct location.
Was du brauchst
Slide the lock on the left side to the unlock position.
Slide the lock on the right side to the unlock position until there is a clicking sound.
Use a plastic opening tool to unsnap the right hand side speaker cover.
Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard.
Remove the Torx screw holding the left keyboard tab in place, and lift it to release.
Turn the computer over on to the back.
Remove the middle screw with a Phillips head #000 screwdriver.
Turn the computer over to the front.
Gently pull at the top and bottom to remove the keyboard.
Peel off the black tape that holds the connection wire.
Flip the keyboard over and carefully unplug the connection wire.
Reverse the steps for proper instillation of the new keyboard.
