Einleitung
If your computer is not recognizing any CD/DVD in the drive, you may have a malfunctioning CD/DVD drive. This installation guide will help you through replacing the CD/DVD drive on the Toshiba Satellite C655D-S5084.
Was du brauchst
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
Wedge a plastic opening tool between the laptop and the CD drive.
Gently pull the CD drive out.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
