Einleitung
The whole Playstation 3 is cooled by a single fan on its bottom side. In this guide, we will remove that fan so that it may be cleaned or replaced.
Was du brauchst
Remove the rubber screw cover near the hard drive cover with a spudger.
Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
Remove the two screws on the front of the power supply.
Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
Unplug the optical drive power cable.
Detach the ribbon cable that connects the optical drive to the motherboard.
Set the optical drive aside.
Remove three screws (Phillips #2) from the wireless board and antenna.
Detach the ribbon cable that connects the wireless board to the motherboard.
Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
Remove the hard drive door with a spudger.
Lift the metal enclosure out of the plastic bottom case.
Remove the three screws (Phillips #2).
Disconnect the fan's power cable.
Lift the fan straight up and out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
