Zum Hauptinhalt wechseln
PSP 300x Trigger Buttons Replacement
Was du brauchst
  1. PSP 300x Trigger Buttons Replacement, Battery: Schritt 1, Bild 1 von 3 PSP 300x Trigger Buttons Replacement, Battery: Schritt 1, Bild 2 von 3 PSP 300x Trigger Buttons Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Trigger Buttons Replacement, Casing: Schritt 2, Bild 1 von 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Trigger Buttons Replacement: Schritt 3, Bild 1 von 2 PSP 300x Trigger Buttons Replacement: Schritt 3, Bild 2 von 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Trigger Buttons Replacement: Schritt 4, Bild 1 von 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Trigger Buttons Replacement: Schritt 5, Bild 1 von 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Trigger Buttons Replacement: Schritt 6, Bild 1 von 2 PSP 300x Trigger Buttons Replacement: Schritt 6, Bild 2 von 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x Trigger Buttons Replacement, LCD Screen: Schritt 7, Bild 1 von 2 PSP 300x Trigger Buttons Replacement, LCD Screen: Schritt 7, Bild 2 von 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  8. PSP 300x Trigger Buttons Replacement: Schritt 8, Bild 1 von 3 PSP 300x Trigger Buttons Replacement: Schritt 8, Bild 2 von 3 PSP 300x Trigger Buttons Replacement: Schritt 8, Bild 3 von 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
  9. PSP 300x Trigger Buttons Replacement: Schritt 9, Bild 1 von 2 PSP 300x Trigger Buttons Replacement: Schritt 9, Bild 2 von 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
  10. PSP 300x Trigger Buttons Replacement: Schritt 10, Bild 1 von 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x Trigger Buttons Replacement, Trigger Buttons: Schritt 11, Bild 1 von 1
    • Remove the screw securing 'L' trigger to the PSP.
  12. PSP 300x Trigger Buttons Replacement: Schritt 12, Bild 1 von 1
    • Remove the white plastic piece that holds the 'L' trigger in place.
  13. PSP 300x Trigger Buttons Replacement: Schritt 13, Bild 1 von 1
    • Remove the 'L' trigger from the PSP.
  14. PSP 300x Trigger Buttons Replacement: Schritt 14, Bild 1 von 1
    • Remove the screw securing the 'R' trigger.
  15. PSP 300x Trigger Buttons Replacement: Schritt 15, Bild 1 von 1
    • Remove the white plastic piece that holds the 'R' trigger in place.
  16. PSP 300x Trigger Buttons Replacement: Schritt 16, Bild 1 von 1
    • Remove the 'R' trigger from the PSP.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
cmcevill
517 Reputation
1 Anleitung geschrieben
Cal Poly, Team 19-2, Maness Fall 2009 Mitglied von Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 37
Letzte 30 Tage: 175
Insgesamt: 18,487
