Zum Hauptinhalt wechseln
How to Tighten the Nishiki Aero II Chain
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: Schritt 1, Bild 1 von 1
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: Schritt 2, Bild 1 von 3 How to Tighten the Nishiki Aero II Chain: Schritt 2, Bild 2 von 3 How to Tighten the Nishiki Aero II Chain: Schritt 2, Bild 3 von 3
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: Schritt 3, Bild 1 von 1
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: Schritt 4, Bild 1 von 1
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
Abschluss
Tobias Elder
113 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-53, Johann Spring 2013 Mitglied von Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 1,309
