Zum Hauptinhalt wechseln
Removal of super-vario 40 braille display
Was du brauchst
  1. Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: Schritt 1, Bild 1 von 2 Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: Schritt 1, Bild 2 von 2
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Removal of super-vario 40 braille display: Schritt 2, Bild 1 von 3 Removal of super-vario 40 braille display: Schritt 2, Bild 2 von 3 Removal of super-vario 40 braille display: Schritt 2, Bild 3 von 3
    • Remove the plastic cover, paper and chipset.
  3. Removal of super-vario 40 braille display: Schritt 3, Bild 1 von 3 Removal of super-vario 40 braille display: Schritt 3, Bild 2 von 3 Removal of super-vario 40 braille display: Schritt 3, Bild 3 von 3
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  4. Removal of super-vario 40 braille display: Schritt 4, Bild 1 von 3 Removal of super-vario 40 braille display: Schritt 4, Bild 2 von 3 Removal of super-vario 40 braille display: Schritt 4, Bild 3 von 3
    • Remove the four screws with a Phillips #00 screwdriver.
  5. Removal of super-vario 40 braille display: Schritt 5, Bild 1 von 3 Removal of super-vario 40 braille display: Schritt 5, Bild 2 von 3 Removal of super-vario 40 braille display: Schritt 5, Bild 3 von 3
    • Remove the connector delicately.
  6. Removal of super-vario 40 braille display: Schritt 6, Bild 1 von 2 Removal of super-vario 40 braille display: Schritt 6, Bild 2 von 2
    • when you put it back together make sure mechanical cells are connected correctly
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sisyphe
350 Reputation
2 Anleitungen geschrieben
2 Kommentare
great guide!  how can I repair a VarioUltra 20?  are the procedures similar?  the device has a problem at point 4 of the sixth cell, the point moves unsteadily, should I replace this whole cell or is it possible to just repair point 4, which is defective?
marcusvinicioslira - Antwort
which professional will likely be able to repair a braille display?  should I look for an electrical engineer or other professional?  I'm blind, I don't repair electronics, but I have a defective braille display that needs to be repaired.  I live in a country where there are no companies capable of repairing this product.  I do not know what to think.  sending the product to a specialized company in another country is very expensive for me.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 1,006
