Zum Hauptinhalt wechseln
Batteriewechsel beim Apple Wireless Keyboard
Was du brauchst
  1. Batteriewechsel beim Apple Wireless Keyboard, Batterie: Schritt 1, Bild 1 von 1
    • Verwende eine Münze, um die Batteriefachabdeckung zu öffnen und diese zu entfernen.
  2. Batteriewechsel beim Apple Wireless Keyboard: Schritt 2, Bild 1 von 2 Batteriewechsel beim Apple Wireless Keyboard: Schritt 2, Bild 2 von 2
    • Schiebe die zwei (drei bei der vorherigen Generation) AA-Ersatzbatterien in das Batteriefach. Vergewissere dich, dass die Plus- und Minuspole in die richtige Richtung weisen.
Abschluss
Um dein Gerät wieder zusammenzubauen, befolge diese Anweisungen in umgekehrter Reihenfolge.
35 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
rab777hp
20.333 Reputation
3 Anleitungen geschrieben
OPEN Mitglied von OPEN
Community
82 Mitglieder
25 Anleitungen geschrieben
5 Kommentare
This works great - as long as the batteries inside did not leak and create a permanent seal for the cap. I managed to get the keyboard working again by removing the batteries through the electronics compartment (remove grey center cover, slide electronics out). It did take some effort (including driving a screw into the stuck battery and yanking it out with pliers) to remove the stuck batteries and all the remains of the leakage, but I ended up with a working keyboard. Only thing is that I need to use the 'backdoor' every time my batteries need replacing, since the battery cover is permanently sealed...
Otto - Antwort
Also have a perma sealed battery cover. Poured vinegar in from middle and let soak over night. Wanna drill into coin slot to try and remove cover but need to get batteries out first. Can I just remove the one screw from logic board and disconnect ribbon cable, to have it slide out the power button end? How careful w cable? Looks like it has 2 tiny clips, do these need to be addressed or can I just pry it off?
William Shouse -
Warm the area where battery screw cover is in a stream of hot water from the faucet. Be careful not to get water into the keyboard or keys. The warmth will sometimes expand the aluminum enough to loosen the screw cover. Worked for mine.
Greg M - Antwort
Thanks!
worked well. Had to push old battery out from electronics cover area. Keyboard working again :)
tankapoet - Antwort
It’s possible, but how can I get it? I am in somali country please help me
saalix49 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 114
Letzte 30 Tage: 513
Insgesamt: 98,125
