Einleitung
The following guide is to remove or replace the screen of the LG VX6000 cellphone.
Was du brauchst
Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
Remove screws and carefully place on an uncluttered surface or in a small container.
Carefully remove the back of the phone gently using your fingernails or tweezers.
Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
As shown in the photos, pull the orange strip through a thin opening at the top of the phone. Once this is done, the top and bottom halves can be separated.
Using tweezers, pull off the small rubber cushions located towards the four corners of the screen.
Carefully open the casing using the iFixit plastic tool by prying each side a little bit at a time. Rotate and open until all the inside clips pop open and the casing opens up.
Gently pull the corner of screen and circuit board up and out of casing to remove screen from the top face plate.
Rotate the screen and the connected white frame away from the logic board.
Carefully peel the adhesive tape that connects the screen and logic board off. The screen can now be removed and replaced with a new screen unit.
