Zum Hauptinhalt wechseln
Apple Studio Display M7649 ADC Cable Replacement
Was du brauchst
  1. Apple Studio Display M7649 ADC Cable Replacement, Stand: Schritt 1, Bild 1 von 2 Apple Studio Display M7649 ADC Cable Replacement, Stand: Schritt 1, Bild 2 von 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 ADC Cable Replacement, Panels: Schritt 2, Bild 1 von 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 ADC Cable Replacement: Schritt 3, Bild 1 von 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 ADC Cable Replacement: Schritt 4, Bild 1 von 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 ADC Cable Replacement, Metal EMI Shield: Schritt 5, Bild 1 von 1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 ADC Cable Replacement: Schritt 6, Bild 1 von 1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 ADC Cable Replacement: Schritt 7, Bild 1 von 2 Apple Studio Display M7649 ADC Cable Replacement: Schritt 7, Bild 2 von 2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 ADC Cable Replacement, USB Port: Schritt 8, Bild 1 von 1
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Apple Studio Display M7649 ADC Cable Replacement: Schritt 9, Bild 1 von 1
    • Remove the cable from the logic board that is connecting the USB port.
  10. Apple Studio Display M7649 ADC Cable Replacement: Schritt 10, Bild 1 von 1
    • Remove the USB port
  11. Apple Studio Display M7649 ADC Cable Replacement, ADC Cable: Schritt 11, Bild 1 von 1
    • Remove these four screws holding down the base of the swing arm to the display and remove it
  12. Apple Studio Display M7649 ADC Cable Replacement: Schritt 12, Bild 1 von 1
    • Remove the four screws holding down the ADC cable to the display
  13. Apple Studio Display M7649 ADC Cable Replacement: Schritt 13, Bild 1 von 1
    • Remove the three connections that connects the ADC assembly to the logic board and screen
  14. Apple Studio Display M7649 ADC Cable Replacement: Schritt 14, Bild 1 von 1
    • Remove and replace the ADC cable assembly.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew Tsao
186 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-20, Maness Winter 2010 Mitglied von Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
What are the two red wires and two black wires ?
Cali Red - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 18
Insgesamt: 2,798
