Zum Hauptinhalt wechseln
LG Cosmos 2 LCD Display Replacement
Was du brauchst
  1. LG Cosmos 2 LCD Display Replacement, Battery: Schritt 1, Bild 1 von 3 LG Cosmos 2 LCD Display Replacement, Battery: Schritt 1, Bild 2 von 3 LG Cosmos 2 LCD Display Replacement, Battery: Schritt 1, Bild 3 von 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 LCD Display Replacement: Schritt 2, Bild 1 von 3 LG Cosmos 2 LCD Display Replacement: Schritt 2, Bild 2 von 3 LG Cosmos 2 LCD Display Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 LCD Display Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 LCD Display Replacement: Schritt 4, Bild 1 von 3 LG Cosmos 2 LCD Display Replacement: Schritt 4, Bild 2 von 3 LG Cosmos 2 LCD Display Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 LCD Display Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 LCD Display Replacement: Schritt 6, Bild 1 von 1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 LCD Display Replacement: Schritt 7, Bild 1 von 2 LG Cosmos 2 LCD Display Replacement: Schritt 7, Bild 2 von 2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 LCD Display Replacement: Schritt 8, Bild 1 von 2 LG Cosmos 2 LCD Display Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 LCD Display Replacement: Schritt 9, Bild 1 von 1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 LCD Display Replacement, Option Buttons: Schritt 10, Bild 1 von 1
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 LCD Display Replacement: Schritt 11, Bild 1 von 2 LG Cosmos 2 LCD Display Replacement: Schritt 11, Bild 2 von 2
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 LCD Display Replacement: Schritt 12, Bild 1 von 1
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 LCD Display Replacement: Schritt 13, Bild 1 von 2 LG Cosmos 2 LCD Display Replacement: Schritt 13, Bild 2 von 2
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 LCD Display Replacement: Schritt 14, Bild 1 von 1
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 LCD Display Replacement: Schritt 15, Bild 1 von 1
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 LCD Display Replacement: Schritt 16, Bild 1 von 3 LG Cosmos 2 LCD Display Replacement: Schritt 16, Bild 2 von 3 LG Cosmos 2 LCD Display Replacement: Schritt 16, Bild 3 von 3
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 LCD Display Replacement: Schritt 17, Bild 1 von 1
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
  18. LG Cosmos 2 LCD Display Replacement, LCD Display: Schritt 18, Bild 1 von 2 LG Cosmos 2 LCD Display Replacement, LCD Display: Schritt 18, Bild 2 von 2
    • Use a tool to pry open the LCD display. Remove the display and the circuit board that it's connected to.
  19. LG Cosmos 2 LCD Display Replacement: Schritt 19, Bild 1 von 1
    Kaufen
    • Remove the plastic piece from the circuit board by unlocking the switch on the plastic piece with a pair of tweezers.
  20. LG Cosmos 2 LCD Display Replacement: Schritt 20, Bild 1 von 1
    • Using a pair of tweezers, remove the tape.
  21. LG Cosmos 2 LCD Display Replacement: Schritt 21, Bild 1 von 1
    • Using either your finger or the plastic opener, disconnect the cable.
  22. LG Cosmos 2 LCD Display Replacement: Schritt 22, Bild 1 von 2 LG Cosmos 2 LCD Display Replacement: Schritt 22, Bild 2 von 2
    • Pull the LCD display away from the circuit board.
    • You shouldn't feel any resistance. If you notice resistance, make sure you have completed the previous step.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nick White
851 Reputation
8 Anleitungen geschrieben
Clemson, Team 13-1, Benson Fall 2013 Mitglied von Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 2,461
