Zum Hauptinhalt wechseln
Les Paul Wireless Guitar Peripheral Neck Connection Replacement
Was du brauchst
  1. Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Les Paul Wireless Guitar Body Teardown: Schritt 1, Bild 1 von 1
    • Remove batteries
  2. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 2, Bild 1 von 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 2, Bild 2 von 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 3, Bild 1 von 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 3, Bild 2 von 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Neck Connection: Schritt 4, Bild 1 von 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Neck Connection: Schritt 4, Bild 2 von 2
    • Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
    • Remove the back of the neck.
  5. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 5, Bild 1 von 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 5, Bild 2 von 2
    • First check to see if the button motherboard is not damaged.
    • Next, make sure the wire is not damaged.
    • Then make sure that the connection motherboard is also not damaged.
    • If any of these parts are damaged, then it will need to be replaced.
  6. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 6, Bild 1 von 1
    • Check to see if the neck connection chip is not damaged inside of the guitar.
    • Make sure that all 8 prongs of the chip are not damaged or broken.
    • If the neck chip is damaged then it will need to be replaced.
  7. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 7, Bild 1 von 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 7, Bild 2 von 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 7, Bild 3 von 3
    • The lock mechanism may be another reason for trouble in your neck connection.
    • Use the guitar tear down to open the guitar to this point.
    • Start by unscrewing the two screws holding down the main connection parts. The first screw is 1 cm and the second screw is 0.8 cm.
  8. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 8, Bild 1 von 1
    • Take the spring off the main connection mechanism. It should come off pretty easily.
    • If this spring is broken or snapped, then it will need to be replaced.
  9. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 9, Bild 1 von 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: Schritt 9, Bild 2 von 2
    • Pull out the main connection mechanism.
    • Make sure that it is not broken or it will need to be replaced.
    • This can be put back together by inserting the mechanism again, attaching the spring and screwing the two screws back in place.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris
881 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 61
Insgesamt: 11,687
