Zum Hauptinhalt wechseln
Disassembling SKIL 4235 Jigsaw Base plate
Was du brauchst
  1. Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: Schritt 1, Bild 1 von 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: Schritt 1, Bild 2 von 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: Schritt 1, Bild 3 von 3
    • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  2. Disassembling SKIL 4235 Jigsaw Base plate: Schritt 2, Bild 1 von 1
    • Using two hands grip both side of the saw and lay on side.
  3. Disassembling SKIL 4235 Jigsaw Base plate: Schritt 3, Bild 1 von 1
    • With bottom of the base plate visible, identify one M4 screw circled in red and remove with Phillips screwdriver (some models have flathead screw, as pictured, and require flathead screwdriver).
  4. Disassembling SKIL 4235 Jigsaw Base plate: Schritt 4, Bild 1 von 1
    • After removing M4 screw, remove the base plate and place to the side. Don't forget to replace the M4 screw near the base plate during re-installation.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam Cardoso
357 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013 Mitglied von UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 2,969
