Zum Hauptinhalt wechseln
Polaroid One-Step 600 Lens Replacement
Was du brauchst
  1. Polaroid One-Step 600 Lens Replacement, Lens: Schritt 1, Bild 1 von 3 Polaroid One-Step 600 Lens Replacement, Lens: Schritt 1, Bild 2 von 3 Polaroid One-Step 600 Lens Replacement, Lens: Schritt 1, Bild 3 von 3
    • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Lens Replacement: Schritt 2, Bild 1 von 3 Polaroid One-Step 600 Lens Replacement: Schritt 2, Bild 2 von 3 Polaroid One-Step 600 Lens Replacement: Schritt 2, Bild 3 von 3
    • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Lens Replacement: Schritt 3, Bild 1 von 3 Polaroid One-Step 600 Lens Replacement: Schritt 3, Bild 2 von 3 Polaroid One-Step 600 Lens Replacement: Schritt 3, Bild 3 von 3
    • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  4. Polaroid One-Step 600 Lens Replacement: Schritt 4, Bild 1 von 3 Polaroid One-Step 600 Lens Replacement: Schritt 4, Bild 2 von 3 Polaroid One-Step 600 Lens Replacement: Schritt 4, Bild 3 von 3
    • Insert spudger in between face of camera and sides where the four tabs are located.
    • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  5. Polaroid One-Step 600 Lens Replacement: Schritt 5, Bild 1 von 2 Polaroid One-Step 600 Lens Replacement: Schritt 5, Bild 2 von 2
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Lens Replacement: Schritt 6, Bild 1 von 1
    • Use spudger to twist the notch on the lens into the opening to remove it.
  7. Polaroid One-Step 600 Lens Replacement: Schritt 7, Bild 1 von 2 Polaroid One-Step 600 Lens Replacement: Schritt 7, Bild 2 von 2
    • Carefully use spudger to release lens, then lift lens out of camera with fingers.
    • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  8. Polaroid One-Step 600 Lens Replacement: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
    • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Doug Jimenez
538 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 16-31, Maness Winter 2010 Mitglied von Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 49
Insgesamt: 16,149
