Einleitung
This guide will show you how to replace the lens on your Polaroid camera if it breaks or gets scratched. However, you should be careful with your Polaroid, as the plastic is very fragile.
Was du brauchst
Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
Fully open the battery/ cartridge compartment by sliding the side tab toward you.
Insert spudger in between face of camera and sides where the four tabs are located.
Carefully use spudger to release lens, then lift lens out of camera with fingers.
In diesem Schritt verwendetes Werkzeug:Microfiber Cleaning Cloths$3.99
Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
