Einleitung
This guide will walk you through the process of replacing a dull or broken cutter blade on a Brother PT-D200.
Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
Fast fertig!
Abschluss
