Zum Hauptinhalt wechseln
Crosley CR42 Power Cable Replacement
Was du brauchst
  1. Crosley CR42 Power Cable Replacement, Power Cable: Schritt 1, Bild 1 von 2 Crosley CR42 Power Cable Replacement, Power Cable: Schritt 1, Bild 2 von 2
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: Schritt 2, Bild 1 von 3 Crosley CR42 Power Cable Replacement: Schritt 2, Bild 2 von 3 Crosley CR42 Power Cable Replacement: Schritt 2, Bild 3 von 3
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: Schritt 3, Bild 1 von 3 Crosley CR42 Power Cable Replacement: Schritt 3, Bild 2 von 3 Crosley CR42 Power Cable Replacement: Schritt 3, Bild 3 von 3
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: Schritt 4, Bild 1 von 3 Crosley CR42 Power Cable Replacement: Schritt 4, Bild 2 von 3 Crosley CR42 Power Cable Replacement: Schritt 4, Bild 3 von 3
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: Schritt 5, Bild 1 von 3 Crosley CR42 Power Cable Replacement: Schritt 5, Bild 2 von 3 Crosley CR42 Power Cable Replacement: Schritt 5, Bild 3 von 3
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: Schritt 6, Bild 1 von 3 Crosley CR42 Power Cable Replacement: Schritt 6, Bild 2 von 3 Crosley CR42 Power Cable Replacement: Schritt 6, Bild 3 von 3
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: Schritt 7, Bild 1 von 3 Crosley CR42 Power Cable Replacement: Schritt 7, Bild 2 von 3 Crosley CR42 Power Cable Replacement: Schritt 7, Bild 3 von 3
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 1-38, Maness Winter 2014 Mitglied von Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 29
Insgesamt: 6,316
