Zum Hauptinhalt wechseln
Crosley CR42 Bushings Replacement
Was du brauchst
  1. Crosley CR42 Bushings Replacement, Bushings: Schritt 1, Bild 1 von 2 Crosley CR42 Bushings Replacement, Bushings: Schritt 1, Bild 2 von 2
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: Schritt 2, Bild 1 von 3 Crosley CR42 Bushings Replacement: Schritt 2, Bild 2 von 3 Crosley CR42 Bushings Replacement: Schritt 2, Bild 3 von 3
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: Schritt 3, Bild 1 von 3 Crosley CR42 Bushings Replacement: Schritt 3, Bild 2 von 3 Crosley CR42 Bushings Replacement: Schritt 3, Bild 3 von 3
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: Schritt 4, Bild 1 von 2 Crosley CR42 Bushings Replacement: Schritt 4, Bild 2 von 2
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: Schritt 5, Bild 1 von 1
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: Schritt 6, Bild 1 von 3 Crosley CR42 Bushings Replacement: Schritt 6, Bild 2 von 3 Crosley CR42 Bushings Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: Schritt 7, Bild 1 von 2 Crosley CR42 Bushings Replacement: Schritt 7, Bild 2 von 2
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: Schritt 8, Bild 1 von 3 Crosley CR42 Bushings Replacement: Schritt 8, Bild 2 von 3 Crosley CR42 Bushings Replacement: Schritt 8, Bild 3 von 3
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Roberto Rosila
319 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-38, Maness Winter 2014 Mitglied von Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 3,062
