Zum Hauptinhalt wechseln
Disassembling the Samsung Laptop Ultrabook NP530U3B
Was du brauchst
  1. Disassembling the Samsung Laptop Ultrabook NP530U3B, Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 1, Bild 1 von 1
    • Remove the 8 small screws.
  2. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 2, Bild 1 von 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 2, Bild 2 von 2
    • Remove the other 6 screws.
    • Remove the hard disk and the RAM slots.
  3. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 3, Bild 1 von 1
    • This is the hard disk - Hitachi 500 GB
  4. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 4, Bild 1 von 1
    • Ensure that the hard disk has been removed. Carefully detach the bottom cover.
  5. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 5, Bild 1 von 1
    • Once the bottom cover is removed, your device should look like this.
  6. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 6, Bild 1 von 1
    • Remove the 4 screws to detach the battery.
    • Remove all of the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
    • The connector won't come out all the way, because the battery pack is in its way.
  7. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 7, Bild 1 von 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 7, Bild 2 von 2
    • This is the Samsung 7.4V 45Wh battery.
    • Ensure that the battery is removed before continuing.
  8. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 8, Bild 1 von 1
    • When the battery is removed, this is how it will look.
  9. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 9, Bild 1 von 1
    • Remove the processor fan.
    • There are 2 screws holding it in place. Loosen and remove them.
  10. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 10, Bild 1 von 1
    • This is the processor fan.
  11. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 11, Bild 1 von 1
    • Remove the processor heat sink.
    • 3 screws hold this part in place. Loosen and remove them.
  12. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 12, Bild 1 von 1
    • Disconnect the antenna cables from the WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  13. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 13, Bild 1 von 1
    • Remove the screw.
    • Lift the latch upwards to loosen the cable.
  14. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 14, Bild 1 von 1
    • Remove the screw.
  15. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 15, Bild 1 von 1
    • Remove the screw.
  16. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 16, Bild 1 von 1
    • To remove the Motherboard, carefully disconnect the cables.
  17. Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 17, Bild 1 von 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: Schritt 17, Bild 2 von 2
    • This is the Motherboard - there is a front and rear view.
Abschluss
34 weitere Nutzer:innen haben diese Anleitung absolviert.
30 Kommentare
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
Luis Orland - Antwort
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
Jose Gustavo Abreu Murta - Antwort
To reset BIOS this NP530U3, only disconnect all power supply (MAIN battery, CMOS battery and power source). And hold press POWER button for 1 min.
warmdk - Antwort
I try it but don't work, do you know another way to do this
manhique -
Hello,
I have seen many screens with model number LTN140AT21-XXX for this laptop. My laptop NP530u4b has a screen LTN140AT21-802. I would like to know if I can use a LTN140AT21-002 screen, or if only is good a screen with number LTN140AT21-8.
thanks for your help.
alex - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 23
Letzte 30 Tage: 74
Insgesamt: 52,899
