Zum Hauptinhalt wechseln
Timbuk2 Messenger Bag Male Cambuckle Replacement
Was du brauchst
  1. Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: Schritt 1, Bild 1 von 3 Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: Schritt 1, Bild 2 von 3 Timbuk2 Messenger Bag Male Cambuckle Replacement, Male Cambuckle: Schritt 1, Bild 3 von 3
  2. Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 2, Bild 1 von 3 Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 2, Bild 2 von 3 Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 2, Bild 3 von 3
    • Remove broken cam buckle. Un-thread strap from bottom plastic loop and take strap off.
  3. Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 3, Bild 1 von 3 Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 3, Bild 2 von 3 Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 3, Bild 3 von 3
    • Thread strap into new cam buckle through the buckle's top opening. Pull strap through the bottom of the buckle, ensuring that the strap goes in FRONT of the connectors as shown.
    • Make sure the strap is not twisted or facing the wrong way when inserting the new cambuckle!
  4. Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 4, Bild 1 von 1
    • Snap buckle into female cam buckle and close the buckle.
  5. Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 5, Bild 1 von 2 Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 5, Bild 2 von 2
    • Thread strap through the bottom of the plastic loop (the loop where the strap was thread though before).
    • Next, thread end of strap through the top end of plastic loop and pull to desired length.
  6. Timbuk2 Messenger Bag Male Cambuckle Replacement: Schritt 6, Bild 1 von 1
    • Congrats! You're all done!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Emilee
1.591 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 3,757
