Zum Hauptinhalt wechseln
Siemens A56 Keyboard Replacement
Was du brauchst
  1. Siemens A56 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Keyboard Replacement, Front Plate: Schritt 3, Bild 1 von 3 Siemens A56 Keyboard Replacement, Front Plate: Schritt 3, Bild 2 von 3 Siemens A56 Keyboard Replacement, Front Plate: Schritt 3, Bild 3 von 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  4. Siemens A56 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Siemens A56 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Siemens A56 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • The keyboard can be easily removed by hand.
    • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
Abschluss
Andrew Corriveau
97 Reputation
1 Anleitung geschrieben
Clemson, Team 6-6, Benson Spring 2014 Mitglied von Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 224
