Einleitung
The speaker clamps on the Kensington Hi-Fi Headphones 33137 connect the speakers to the headband. This guide shows you how to remove these parts.
Was du brauchst
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
Use the screwdriver to pry the inner headband covering loose.
Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
Pull the speaker clamp so that the metal lifts free of the headband.
