Zum Hauptinhalt wechseln
HP Pavilion dv1000 Media Keys Replacement
Was du brauchst
  1. HP Pavilion dv1000 Media Keys Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Media Keys Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Media Keys Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv1000 Media Keys Replacement: Schritt 3, Bild 2 von 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Media Keys Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv1000 Media Keys Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv1000 Media Keys Replacement: Schritt 4, Bild 3 von 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Media Keys Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Media Keys Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv1000 Media Keys Replacement: Schritt 6, Bild 2 von 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion dv1000 Media Keys Replacement, Media Keys: Schritt 7, Bild 1 von 1
    • Turn the laptop upside-down again.
  8. HP Pavilion dv1000 Media Keys Replacement: Schritt 8, Bild 1 von 2 HP Pavilion dv1000 Media Keys Replacement: Schritt 8, Bild 2 von 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tyler Latour
266 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 Mitglied von UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G7
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 647
