Zum Hauptinhalt wechseln
Siemens A56 Clean Charging Port Replacement
Was du brauchst
  1. Siemens A56 Clean Charging Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Clean Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Clean Charging Port Replacement, Clean Charging Port: Schritt 3, Bild 1 von 1
    • Use soft brush to clean the charging port of the phone. If needed, use alcohol and a q-tip for more thorough cleaning.
Ziellinie
Lauren Young
322 Reputation
3 Anleitungen geschrieben
Clemson, Team 6-6, Benson Spring 2014 Mitglied von Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 243
