Zum Hauptinhalt wechseln
Dell Inspiron 1545 RAM Replacement
Was du brauchst
  1. Dell Inspiron 1545 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 RAM Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 RAM Replacement, Base Cover: Schritt 4, Bild 1 von 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 1545 RAM Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 RAM Replacement, RAM: Schritt 6, Bild 1 von 1
    • Spread apart the securing clips on each end of the memory stick until the memory stick pops up.
    • Remove the memory stick from the laptop.
    • Repeat these steps to remove the second memory stick.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathan Lemay
3.052 Reputation
15 Anleitungen geschrieben
Cal Poly, Team 9-14, Regan Spring 2014 Mitglied von Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 2,874
