Zum Hauptinhalt wechseln
Samsung Galaxy Tab 3 7.0 Battery Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy Tab 3 7.0 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 3 7.0 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
  2. Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 2, Bild 3 von 3
    • Working slowly and carefully, move around the entirety of the face of the device. Small plastic clips should release, if not, apply gentle outwards pressure until you hear the clips popping off.
  3. Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 3, Bild 3 von 3
    • To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
    • Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
    • Once the battery is removed, it should look as it does in the third picture.
  4. Samsung Galaxy Tab 3 7.0 Battery Replacement: Schritt 4, Bild 1 von 1
    • To finish battery replacement, place your new battery where the old battery was in your device, as shown in the picture.
Abschluss
57 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 7-20, Regan Spring 2014 Mitglied von Cal Poly, Team 7-20, Regan Spring 2014
CPSU-REGAN-S14S7G20
4 Mitglieder
10 Anleitungen geschrieben
6 Kommentare
Don't forget to reset the time and date when your done.
Some of the apps will not work and the operating system will not tell you that this is the problem.
cpessaro - Antwort
good job for making this as least complicated as possible i completed the guide
Alburt Einstine - Antwort
Great guide..... If you don't have the plastic tool, my thumb nail worked just fine
Bruce Wiggins - Antwort
Thanks for this great guide.
When attaching the new battery it helped me to actually attach the wiring connector before final placement of the battery. Also, I found it easier to put the single screw in first before pushing the battery all the way down and starting the three on the other side. The cscrew holes in the replacement battery have to be PERFECT and if they’re just slightly off you can’t get the one lonely screw started if you put the other three in first.
Tkappock - Antwort
I enjoied the guide it was realy easy the video was varry helpfull. I do have a question is there any way to test the batery to make sure that is realy the problem, before i go replaycing it?
John Tahos - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 80
Insgesamt: 165,394
