Zum Hauptinhalt wechseln
Lenovo IdeaTab A2109 Digital Board Replacement
Was du brauchst
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: Schritt 1, Bild 1 von 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 2, Bild 1 von 2 Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 2, Bild 2 von 2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 3, Bild 1 von 3 Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 3, Bild 2 von 3 Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 3, Bild 3 von 3
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 4, Bild 2 von 2
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 5, Bild 2 von 2
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: Schritt 6, Bild 1 von 1
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian
565 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-19, Regan Spring 2014 Mitglied von Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 3,037
