Einleitung
The removal of the top panel involves the removal of the front case to be able to reach the screws necessary for the removal of the top panel.
Was du brauchst
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Use the spudger to raise the corner of the case from the camera.
One component of the front case should now be separate from the camera.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
Using the spudger again, carefully pry from the top of the camera to remove the back frame.
The back frame is fragile, so use the spudger gently.
Use the spudger tool to go around the seam of the top panel. The top should easily lift off.
This is what the camera and top panel should look like after you have completed the guide
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Hey Steven! This is all wrong! That's not the wright order: actually the top panel is the first part that can be removed, you don't need to tear down the rear panel and the front handgrip.. (it also may cause the damage of the rear panel!).
So, in order to remove the top panel just follow this order:
STEP 2
STEP 5 (Just the upper screw (not that one between HDMI and USB port)
STEP 6 (Just the two 4mm screws)
STEP 10
STEP 12
Its a lot easier ;)
Daniele
