Zum Hauptinhalt wechseln
Kodak EasyShare C713 Battery Door Replacement
Was du brauchst
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: Schritt 2, Bild 1 von 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: Schritt 3, Bild 1 von 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: Schritt 3, Bild 2 von 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare C713 Battery Door Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare C713 Battery Door Replacement: Schritt 4, Bild 3 von 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: Schritt 5, Bild 1 von 2 Kodak EasyShare C713 Battery Door Replacement, Battery Door: Schritt 5, Bild 2 von 2
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 26-19, Regan Spring 2010 Mitglied von Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Where do I buy a new battery door. Cheers, Peter
Peter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 5,177
