Zum Hauptinhalt wechseln
RIDGID R84015 X2 Planetary Gear Replacement Guide
Was du brauchst
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: Schritt 1, Bild 1 von 2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: Schritt 1, Bild 2 von 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 2, Bild 1 von 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 3, Bild 1 von 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 3, Bild 2 von 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: Schritt 4, Bild 1 von 1
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 5, Bild 1 von 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 5, Bild 2 von 2
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 6, Bild 1 von 1
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 7, Bild 1 von 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: Schritt 7, Bild 2 von 2
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Evan Long
262 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 15-48, Garner Spring 2010 Mitglied von Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 6,234
