Zum Hauptinhalt wechseln
RIDGID R84015 X2 Speed Switch Replacement
Was du brauchst
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: Schritt 1, Bild 1 von 2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: Schritt 1, Bild 2 von 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: Schritt 3, Bild 1 von 2 RIDGID R84015 X2 Speed Switch Replacement: Schritt 3, Bild 2 von 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: Schritt 4, Bild 1 von 1
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: Schritt 5, Bild 1 von 2 RIDGID R84015 X2 Speed Switch Replacement: Schritt 5, Bild 2 von 2
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Evan Long
262 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 15-48, Garner Spring 2010 Mitglied von Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 3,606
