Zum Hauptinhalt wechseln
LG L1200 Keypad Replacement
Was du brauchst
  1. LG L1200 Keypad Replacement, Logic Board: Schritt 1, Bild 1 von 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. LG L1200 Keypad Replacement: Schritt 2, Bild 1 von 1
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. LG L1200 Keypad Replacement: Schritt 3, Bild 1 von 1
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. LG L1200 Keypad Replacement: Schritt 4, Bild 1 von 1
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. LG L1200 Keypad Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to disconnect antenna wire.
  6. LG L1200 Keypad Replacement: Schritt 6, Bild 1 von 1
    • Use the IPod opening tool to pop out the logic board.
  7. LG L1200 Keypad Replacement: Schritt 7, Bild 1 von 1
    • Use the IPod opening tool to disconnect the main ribbon.
  8. LG L1200 Keypad Replacement: Schritt 8, Bild 1 von 1
    • Once the ribbon is detached, remove the logic board and replace if necessary.
  9. LG L1200 Keypad Replacement, Keypad: Schritt 9, Bild 1 von 1
    • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
  10. LG L1200 Keypad Replacement: Schritt 10, Bild 1 von 2 LG L1200 Keypad Replacement: Schritt 10, Bild 2 von 2
    • Using a spudger, lift the keypad off of the tabs.
Abschluss
Cal Poly, Team 6-14, Maness Spring 2010 Mitglied von Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,066
