Zum Hauptinhalt wechseln
Disassembling JVC GR-D290U
Was du brauchst
  1. Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: Schritt 1, Bild 1 von 2 Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: Schritt 1, Bild 2 von 2
    • Open the liquid-crystal display (LCD) screen.
    • Using a Phillips #1 screwdriver, remove the two hinge screws.
    • Remove the hinge cover. Shut the screen after the cover is removed.
  2. Disassembling JVC GR-D290U: Schritt 2, Bild 1 von 3 Disassembling JVC GR-D290U: Schritt 2, Bild 2 von 3 Disassembling JVC GR-D290U: Schritt 2, Bild 3 von 3
    • Flip the camera over to look at the bottom panel.
    • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
    • Push the eject button beneath the bottom panel to open the cassette cover.
    • Shut the cassette cover.
    • Place the camera upright.
  3. Disassembling JVC GR-D290U: Schritt 3, Bild 1 von 1
    • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
    • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
    • Replace the dark gray tab and close the LCD screen.
  4. Disassembling JVC GR-D290U: Schritt 4, Bild 1 von 1
    • Go to the side of the camera that is opposite the LCD screen.
    • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
  5. Disassembling JVC GR-D290U: Schritt 5, Bild 1 von 2 Disassembling JVC GR-D290U: Schritt 5, Bild 2 von 2
    • Go to the side of the camera that has the LCD screen.
    • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
    • Pry the top cover from the bottom cover until you hear a snapping sound.
    • Gently remove the top cover from the camera base.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
justin chen
47 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 18-69, Johann Spring 2010 Mitglied von Cal Poly, Team 18-69, Johann Spring 2010
CPSU-JOHANN-S10S18G69
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 3,883
