Zum Hauptinhalt wechseln
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: Schritt 1, Bild 1 von 2 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: Schritt 1, Bild 2 von 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: Schritt 2, Bild 1 von 2 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: Schritt 2, Bild 2 von 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: Schritt 3, Bild 1 von 2 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: Schritt 3, Bild 2 von 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
Abschluss
CSU Fullerton, Team 2-4, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 357
