Einleitung
This guide will demonstrate the removal and replacement procedures for an IBM ThinkPad T42 Modem Daughter Board.
Was du brauchst
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
