Zum Hauptinhalt wechseln
HTC Desire 700 Dual Sim Front Facing Camera Replacement
Was du brauchst
  1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Battery: Schritt 2, Bild 1 von 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Remove 8 Torx Screws: Schritt 3, Bild 1 von 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Prying Off Rear Panel: Schritt 4, Bild 1 von 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Disconnect Vibrator Wire: Schritt 6, Bild 1 von 1
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Front Facing Camera Replacement: Schritt 7, Bild 1 von 1
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Front Facing Camera Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Front Facing Camera Replacement: Schritt 9, Bild 1 von 1
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Camera: Schritt 10, Bild 1 von 1
    • Remove the camera using the plastic opening tool as shown.
Abschluss
Steven Pate
191 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 9-3, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 749
