Zum Hauptinhalt wechseln
Air Blasters Tek Six Barrel Replacement
Was du brauchst
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: Schritt 1, Bild 1 von 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: Schritt 1, Bild 2 von 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: Schritt 1, Bild 3 von 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: Schritt 2, Bild 1 von 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: Schritt 2, Bild 2 von 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: Schritt 2, Bild 3 von 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: Schritt 3, Bild 1 von 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: Schritt 3, Bild 2 von 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: Schritt 3, Bild 3 von 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: Schritt 4, Bild 1 von 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: Schritt 4, Bild 2 von 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: Schritt 4, Bild 3 von 3
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: Schritt 5, Bild 1 von 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: Schritt 5, Bild 2 von 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: Schritt 5, Bild 3 von 3
    • Lift the barrel, pulling it out from under the black trigger catch
Abschluss
USF Tampa, Team 3-1, Brown Fall 2014 Mitglied von USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 430
