Einleitung
Replace your phone's earpiece speaker to improve call clarity.
Was du brauchst
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Insert the pin into the SIM card opening located on the right-side of the phone.
Gently push in until the SIM card clicks, and then pull the pin and SIM card out.
Repeat this process for the additional SIM card.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
Firmly push up on the back panel with your thumbs.
Lift up the back panel from the top right corner and gently pull it away from the phone.
Remove the following screws securing the logic board to the main frame:
Five 2mm Phillips #000 screws
Two 2.5mm Phillips #000 screws
Push down the yellow plastic lining at the top of the battery and remove the two 2.5mm Phillips #000 screws.
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Use the pointy end of a spudger to pry the antenna connector off of its socket.
Use the pointy end of a spudger to gently pry the following connectors out of their sockets:
silver LCD cable connector
silver Headphone jack cable connector
Use the pointy end of a spudger to gently pry the following connectors out of their sockets.
Sliver Micro-USB cable connector
Copper battery cable connector
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
Wedge the flat end of a spudger underneath the bottom left of the metal tab.
Run the spudger along the bottom edge of the metal tab and gently pry upward.
Use the pointy end of a spudger to wedge underneath the earpiece speaker, and gently pry upward.
Use tweezers to remove the earpiece speaker from the frame.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
