Zum Hauptinhalt wechseln
Sony Xperia Z3 Dual Battery Replacement
Was du brauchst
Einführungsvideo
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Xperia Z3 Dual Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z3 Dual Battery Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z3 Dual Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
  3. Sony Xperia Z3 Dual Battery Replacement: Schritt 3, Bild 1 von 1
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: Schritt 4, Bild 1 von 1
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: Schritt 5, Bild 1 von 1
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: Schritt 6, Bild 1 von 1
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Sophia
43.810 Reputation
62 Anleitungen geschrieben
2 Kommentare
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Antwort
Just finished this guide thank you!
Seb Carroll - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 28,187
